connection error/ emails disappering
Timmaaay4
Member
1st off i have 3 email accounts set up on the droid, 1 gmail, 1 pop3 for work, and 1 aol. that i also have forwarded to my gmail account.
the problem that i am having is on my pop3 for work i have had a couple of errors it will receive the title of the email but not the body/attachments. i get a thinking circle in the middle of the screen and can not move the screen, then it pops up with a connection error. the wired thing is that i can send an email right after this to say my gmail and i get it with in 30 seconds. after that i went back into my work account and hit refresh same thing connection error.
The 2nd problem that i am having is one the same account were the emails that i have received that i haven't deleted disappear. does this happen because once i open outlook it pulls it from the server or what. this did not happen on my bb.
any suggestions would be great as i need this problem resolved so i can do business on my phone.
thank you
:Di think i have figured out a solution to this problem.
if you star the emails that you want to keep a starred folder is created.
i have tested this numerous times the key is to star it and then delete it from the inbox. a copy is sent to the star folder. if you do not delete it once i open my outlook up and it pulls the email from the server the ones which i did not delete disapper, once the droid refreshes that account.
i hope this will help some else
My account with gmail seems to work with starring them. however, the account with M/S outlook just makes the emails disappear and states"load more messages". What do I do?
