Help "Connection Failed" message on "Desk Clock"
Narek
I had upgraded the firmware of my phone yesterday.
Everything works ok besides "Desk Clock". Its shows only the clock and the date but it should show the weather too. And after 10 seconds it shows "Connection Failed" message, although I have an internet connection.
How can I fix this problem?
I'm not familiar with that app/widget specifically as i dont have it on mine, but it may be worth going into your applications setup for it to see if you can clear cache and/or clear data for the Desk Clock app.
Failing that reinstall it.
