Root Connection issues after Rooting
phoomp
I rooted my xperia arc this evening with the zergrush method (instructions at addictivetips). Now, I'm encountering connection issues:
- Google Play says "No connection. Retry"
- Google Plus says "Can't load data. Check your connection"
- Browsers (Browser, Dolphin, Boat, FF) work. Though, initially, Browser said "Please access www.sonyericsson.com from your computer's web browser to get correct settings" and then "(Error) WiFi Detected. We are unable to authenticate you as you are not currently on the Rogers or Fido Mobile Networks. Please disable your WiFi connection and launch your browser to try again"
Other apps not working:
- Path
- Facebook
- Maps (though, it works in Poynt)
- Netflix
Other apps that ARE working
- flickr
- Instagram
- Rdio
- Poynt
Any thoughts?
