Help connection problem
I need help! :( after installing juice defender and playing around with *#*#4636#*#*. I switched the radio band from default(didnt press anything) to US and then to automatic.
Mind you all this was working all fine before i messed it up :(..
Signal is totally fine. I can only connect to gsm only. the moment i switch to wcdma only signal drops. but when i try gsm/wcdma auto it connects to edge for then switches to h+/3g briefly before it drops the signal again.
i had this message "network search not available when packet connection active..."
I've added the apn's respectfully as i did before. Will a factory format help? will i have to unlock the phone again? I ask because i don't have the unlock code as i bought it unlocked from some person;can i find out what the code is?
