I live in Thomasville, GA. I purchased the HTC EVO V 4G from Radioshack. After the phone took 2.5 days to finally activate, everything was working just fine. Later that same evening while I was downloading some applications via the 3G network, the 3G connection dropped and I was no longer able to connect. I think the phone may have done an update as the PRL went from 61007 to 61008. I returned to Radioshack to see if they could get it working again, instead they replaced the phone with a new one thinking it was a hardware issue. After receiving the new phone (with PRL 61007), I was still not able to connect to the 3G network, not at all. Radioshack called Virgin Mobile and was told there is no manual programming for this phone, that it is all done over-the-air. So basically leaving me SOL. I did take the phone with me to Tallahassee, FL last weekend thinking a different sprint tower might help, but still nothing...
I've since downgraded to the Motorola Triumph. So far I've not had a connection problem with this phone on the 3G network or otherwise, although I have run into other quarks that are irritating me, but that's for another thread.
So just beware, if you are looking to purchase the HTC EVO V 4G on Virgin Mobile's network, I just hope you have better luck than me.
I just happened to see my signal bar go from partial to empty to full within few seconds so decided to take a look at the signal strength and it was at -120 dBm with full signal bars. Obviously, it was misreporting the signal strength. So I tested sending text and receiving phone calls, which then gave me that error code. I was able to resolve the issue by turning off the wifi and that helped the signal strength increase to -80 dBm immediately. Since then I've restarted the device for safe measures, but I have to say it is concerning.
