Help Connectors under battery door
DPiddy
There are 5 or so connectors behind the battery door that are intentionally exposed. What are they there for? They look like they give the ability to add antenna hardware and oneconnection is a definite RF connector and the others look similar.
Am I the only one that has these. If they allow us to connect additional antenna hardware that would be awesome.
Seems like no one knows. one of the connections its definitely an RF connection. The only reason, I think you'd have that is to add antenna hardware.
