I upgraded to a Razr and have been having some issues with it and am debating going to a Rezound. I previously had the Dinc and that's the only Android phone I've used, so obviously, I'm used to HTC. Here are my areas of concerns I hope someone can help me with.
1. Google Music and BT integration for car
I have a Mazda and my Dinc worked seamlessly with it. I could use my cars controls to skip tracks, volume, etc. If my BT was on, and I hit AUX, GMusic would start immediately. If I switched to the radio or turned my car off, it would stop. If I turned off my car mid-song, it'd start back up where it left off when I returned.
Unfortunately, the Razr is iffy on all accounts and I use GMusic a lot when driving. It won't change tracks (well, sometimes it will), if I turn to AUX, it doesn't start, I have to start it from the phone. Volume doesn't work.
Does anyone use GMusic and BT in their car? Does it work nicely? Having a Mazda is a plus, lol.
2. Keyboard Lag
Although I'm not the best at typing, my Dinc never lagged and always kept up. How's the Rezound? The Razr is absolutely horrible and I hate typing on it. It's becoming a dealbreaker.
3. Reception/Signal
My Dinc gets nothing at my house (I'm in a dead area). Usually it's at 1 bar 3g or maybe 1x, but usually neither. So it kills my battery unless I remember to put it on Wifi. My Razr on 4g gets 3 bars. On 3g, gets 2 bars. My friend's Dinc gets 1 bar on 3g (so I know it's not just my phone). How's the Rezound? Would you say average? Better than average?
4. Battery Life
I know 4g kills batteries, but I also know my Razr will only last 8-12 hours...and that's not really using it (although it still receives mail and stuff). I've been reading and it sounds like the Rezound and Razr are about the same. This is when I want a Maxx.
5. Smart Actions
I just realized....is that a Moto thing?
6. Opening Apps/menus
Everything I've read points to the Razr being faster. But after 2 weeks, my is lagging big time. 4-5 seconds just to open the "add a widget" screen. I see a few posts here...anyone else see their phone slowing down after adding lots of apps and personalizing their phone? My Dinc is faster than my Razr.
Thanks for getting through this. I'm trying to decide and although I have had the Razr for a bit over 2 weeks now, I can't use the Rezound for that long and return it for a Maxx. I'm trying to do this the hard way....by asking people about it instead.
2. Keyboard Lag
3. Reception/Signal
4. Battery Life
5. Smart Actions
