Helenoftroy08
I am running Pete's virgin deodexed FRF84B, with Chevy's LV 1.0 Ghz kernel.
I edited .png files in framework-res.apk; the sdcard preparing icon and also the usb connected icon. I used this method:
Use terminal, since ADB doesn't work.
su
cp system/framework/framework-res.apk /sdcard
(edit files on your computer opening the framework as an archive using 7zip. put the file on the sd card)
assuming that you aren't in SU anymore..
su
cp /sdcard/framework-res.apk system/framework
chmod 644 system/framework/framework-res.apk
sync
reboot
(found here: Best way to edit/mod "framework-res.apk" in FROYO? - Droid Forum - Verizon Droid & the Motorola Droid Forum)
They are not the .9 png files, and the icons changed without problem, but immediately after a reboot almost every program on my phone is force closing. I would love ne suggestions the community has. Thanks!
su
su
sync
reboot
