Help Constant *Message not sent* error
does anyone else get a TON of message not sent notifications? I get them a LOT. Im a big texter and clear the conversations frequently because ill build up 200+ a convo rather quickly. But its so aggravating that i keep getting this error over and over. My iPhone sent the message EVERY time and never had an issue. Yes they do send with a little time but thats not the point, it should NOT be doing this.
Are you using WIFI?
yes, it happens to me. At least once or twice a day. not a big deal for me, but maybe you can call t-mobile and see if everything is provisioned correctly.
I get that as well from time to time. It seems to be only when I'm in certain areas though. I think its probably more of a network thing than the phone. certain areas may not have as many text carrier channels as others so its like getting a busy signal.... the phone will keep trying to send it and when a channel frees up it will go through.
I suppose it could be a bug with the phone but you'd think we would have heard more about it by now if that were the case.
what i do is just open a task killer lol, and i kill messages, so it will restart itself.
Some people say that all task killers cycle themselves, but I disagree, I believe they only kill the task once. But then again I also kill the task killer itself whenever I'm done so that might be a reason.
Task killers are very useful to kill a single task, its auto killers that are the problem. Sounds like you are using it correctly.
Hmm, weird. Whenever I have that "Message not sent error" it sends anyways, at least according to my message receivers. So, I learned after resending the message 20 times, they tell me they get that message anyways...20 times. hah
yeah it sends it no matter way 99% of the time. i just got about 8 in a row. SO ANNOYING.
Anyone else getting random network switches? Out of nowhere my network starts to register with AT&T. Just checking to see if that might be part of the problem.
hey all i have got a problem. My phone Lg optimus p970 appears to have trouble with sending texts at times.A red triangle comes up and it says ''message failed' or something like that,well basicly reetting the phone doesnt help and neither does having the app called Handcent or whatever, any help? i cant bare this problem,thanks maya
