Help Constant redraws?
mikejaret
Member
Hi everyone, i have a rooted dx2 and I somehow seemed to really botch it. I did a my backup restore and that permanently screwed up swype, even tried a restore and swype will not run.
The biggest issue is that both adwex and go launcher both constantly crash and redraw, while it is fairly quick on this phone it is still a nuisance. Anyone got a fix?
By restore, do you mean factory reset? I you have done a reset and still issues, it may be borked until recovery solutions are available.
getting a lot of redraws with launcherpro as well. a reboot fixes it, but it eventually comes back. i don't know how much better the stock launcher performs, i didn't try it long enough...
Oh, I thought you were having issues that you were not before (I had similar issues with the gTablet, but impacted other apps too).
I know ADW EX's recent update makes it redraw constantly on my DX also, so maybe that is the culprit. Can't speak for other launchers though.
