My contacts have been saving into the backup assistant for some time and I want them in my gmail contacts account. I already changed to save to gmail, but how do I get the others over and sync'd?
Do you have a gmail accout set up on your PC? If not then set it up and see if they will populate there. If they do then they should poplulate in the phone also.
they do not, they are displayed on the phone from the backup assistant. I need to get them from the backup assistant to my gmail contacts. dont know how to do this
They should come over when you do a google sync...they should be listed in a separate group "All other contacts", in your google contacts section. I had a similar issue the other day when I looked for them.
