Help Contact Notes info disappears
sam65
could be losing my mind here but I've noticed that when I have added information to my contacts (note section particularly) when I go to check it there is no sign of it, and on one occaision I was checking my recent saved entry and the note section vanished infront of my eyes!!
My contacts sync with Google and when I add the info to the notes section in google on my laptop it stays on the phone ok.
Any suggestions??
As an afterthought, after the 2.2 update (with Orange) I did switch my googlemail address to gmail and I had a few issues at that time (and googlemail still shows for contacts)
All help gladly received
If you add a number to a contact on your phone, does it sync to gmail? Sounds like you're syncing one way only.
