Contact shorcut...........
fuzio1963
Here is what i noticed; try to make a shortcut for your contacts. In my contacts list, all is fine, it shows picture of contact, the right one. But after creating shortcut, picture shows either "no picture" or someone else's......weird.
I just tried it, and it did the same...no picture, but if you use the contact quick task widget, the picture shows up. Has to be a bug, unless it takes awhile for the photo to update itself and populate.
