It's possible yes, when using the official Twitter app.
Go into setting for the app and then Sync Contacts and choose 'Sync with exising contacts'
Go into your People, find the person and press link, then under 'Add contact' press 'All contacts' and all your Twitter contacts should be in the list!![]()
When I do this, either sync existing or sync all, the Linked > Add contact > All contacts list only displays my Google contacts and nothing else, no Twitter, no Facebook, just Google.
Is it me or are there quite a few problems with various apps' integration on the Desire.
Bearing in mind it works for me I'd say there must be something wrong with your settings.
Do you have your sync options enabled for the two services?
