Help Contacts not showing up
lilcee
When I try to put in a new contact, after I hit done, it doesn't show up on my contact list. But if I do a search for it, it shows it's there.
Nevermind, I think I figured it out
When you solve your problem, you should tell us how you did it. This helps other people with the same problem. In this case, you probably changed the display options in your contacts menu.
Oh, sorry. New to this. I had my data turned off. When I turned it back on, it showed up. Do I have to have it turned on whenever I add a new contact?
You shouldn't have to. I know there is a setting that's says something like " only show contacts with phone numbers " and if that's checked contacts with just email addys but no numbers won't show up.
Hmm, guess that's not it. I tried to add another contact with data turned off and it showed up. Now I don't know what it was. lol. This phone is confusing to me. I must be too old or dumb for a smart phone lol
I know the answer... Worried lot how this kind of big problem is not identified by google... but then only came to know that is the contact category is unassigned or unknow it won't display change it and check it works nice.
