Help contacts on home page
83tonio
so am on my home screen and i move the screen once to the right and i see i can add contacts. so i added 3 contacts and now i can just hit the message icon or the phone icon for each contact i have on my home screen. now am using the atrix right from the store no root so if u lost already i dont know what to say. now what i need to know now is how do i add a forth contact cause i deleted one.
I have a similar question in the Support & Troubleshooting sub-forum but I was able to figure out the answer to your question. Long tap (touch & hold) the home screen. When the menu pops up, select "Motorola widgets" then "Contact quick tasks." Select then contact you want to add and then you can select the quick tasks that you want.
I used that as a work-around on my issue (deleting a quick task). Hope that helps.
yep, long touch/tap/hold will do it. lol
or, you can also press the menu button (bottom left of the phone) when ur on any of the screens, and simply go to the 'add' option, and you will get the same result as the long touch
