Contacts pictures
Robinelli
If you removed your acct for some reason you may find your phone unable to sync w/ facebook photos and available only for updates. If this happens to you:
Go to Contacts
Click Menu
Click Add Friends
Click Facebook (not add account)
Check mark the friends you would like to add... IMPORTANT name spelling must be the same to go over without a hitch.
If the name is different and you've ALREADY added the facebook photo... Click on the name in the contact list. Click link... a suggestion should pop up. Select it. HTH!
I got my phone Sunday, and have never been able to set my Facebook to sync. I downloaded Facebook for Android which is nice, but I don't get notifications sent to my phone. I also only get Yahoo! Mail notifications randomly, which I don't understand.
Thanks. Unfortunately, I've never been able to get it to log-in successfully, so that won't work. Do facebook notifications automatically show up for you, or do you have to go through the facebook app manually to check for messages/notifications?
I like how you link contacts on this phone and love that I can have 1 contact have their twitter, facebook, and my gmail contact info all linked and synced. Marking the appropriate one as default makes the contact's name appear how I want it but I can't figure out how to pick which picture shows up for the contact. If the gmail contact has a picture associated I can remove it but I can't choose between facebook or twitter per contact.
any ideas?
I had the same problem with both Facebook and Twitter. Here's what I did to fix both of them:
  • Log in to the desktop version of Facebook/Twitter/whatever the problem app is
  • Go to the application settings (Facebook:Account>Application Settings; Twitter: Settings>Connections)
  • Remove or Revoke the Samsung option from this list
  • Try the sync again on your phone.
This worked for me on both accounts. I spent a couple of hours fighting with this, so hope it helps others out.
One particular example is a friend who has a google account, facebook, and twitter account Linked.
The Google account and the Facebook account both have profile pictures, yet it uses the default Twitter picture. How do I pick which one is used?
Iam also having a problem staying signed in it keeps signing me out after couple hrs,i get a notification on the task bar telling me to r enter password face book authentication failed.I didn't creat a new thread cause this seems closer to my issue.
This is great. I bet this will help a lot of people.
Tried the steps above but still not working. Awesome.
Edit: Well I tried something else. It's telling me "Sync all contacts processing..."
If it works, I'll post my steps.
Edit #2: Nope. Back to the Sync error.
