Help contacts problem
I have a contact in my phone I am unable to find. So I looked up the number online. When I dialed it, it showed as being in my contacts. I added a second number and made sure the contact had a name. When I look in my contacts, its not there. Why would that be?
You might need to adjust your display settings; make sure it is set to display all:
contacts -> settings -> more -> display options. This will alow you to set what is and what is not diplayed. I hope this helps.
check your entire contact list. When I exported to google and then imported, I had few that swapped first and last names around and so were out of order. I also had one that had an extra space in front of the last name, so that showed up at the top of the list. Took me a full day to get all my contacts the way I wanted them.
