Help Contacts wont show bit they're there! ??!?
brute347
Hello,
So I've noticed that if I go into my testing app and start typing the name of a contact the look contact is there. BUT if I go into my contacts the contact isn't there... wtf is that!?!?!?!? How do you fix that
I have experienced the same phenomena. To be honest, I am not sure what causes it, though I suspect it depends on where the contacts are stored, either on the phone or Google's servers. I recently put the app called "syncmypix" on my phone to address a facebook pic issue, and noticed that it corrected the issue I had with the contact not coming up in search as well. I don't know if it will fix your issue as I don't know if it fixed mine (the result is there but I'm unsure about ascribing it causality), but since it's free it can't hurt for you to give it a shot
Yeah isn't that so weird!?!?!
Another thing- when ever I enter a new contact it asks me if I want to put it on google servers on back up and I always check off * use this method for all other entries* and it always always resets :/
I wanna see if I can find a solution before I install apparently
I think your right about where the contact is stored but I aways use google so I dunno
