iRhyiku
I cant use my phone.. when i turn it on, it does all the start-upy stuff, then when it loads the home screen it says:
golauncher is not responding
with an option to force close..
I cant do nothing.. choosing force close, just makes the option appear again, i cant get into settings to change default home launcher or anything!
Please help! I dont want to factory reset.. done to much work on it D:
EDIT:
Actually nevermind.. i got lucky :')
I had widget locker installed and it worked, i added a shortcut to setting and erased golauncher ex
EDIT:
