Root Continuous Force Close - Help!
tmacrae
Gtab was fine yesterday. Powered it on today and am getting continuous force close ("android.process.acore has stopped"). Can't even read email messages.
Running VEGAn 5.1.1 and ClemPatchTNTVEGANZPAD2.zip from 2011-03-12.
Any idea what needs to be done?
Usually clearing the data from your contacts.apk fixes these errors. If you can get into settings that is.
That did it! I was able to get into settings/Applications and actually cleared data, cache in all 3 contact applications, and no more Force Close.
Thanks!
Had to do this w/ my dad's gTablet on two different occassions. It may happen again down the road so be prepared to do the fix again just in case!
I had this happen on mine for no reason! I restored my backup and all was well....now I know what to do,thank you!
Always good to make a weekly backup! I stupidly neglected the gTablet and then it went crazy too, FCing all over the place. Had to wipe data/factory reset to get it to behave again. Never again will I forget to back it up.
