Control music while locked?
durangojim
Is there a way, like with the Incredible and the Fascinate to control music you're listening to while locked on the lock screen? Is this part of blur or do you have to dl a 3rd party app to make that happen?
Thanks.
with the screen on at the lock screen you can do what quickaudi said above. with the screen off you can only control the volume.
Not only can you control music from the stock screen, but an app like WidgetLocker lets you add any kind of widget to the lock screen, making your control options basically only limited by the developers' ability to write widgets.
