UncleBud
Just found the coolest app AirDroid manage your Prevail from your pc desktop!
https://market.android.com/details?id=com.sand.airdroid&hl=en
Enjoy below features after installation from the comfort of your favorite web browser on desktop or other devices:
*Files
Transfer files between Android devices and computers.
Cut, copy, paste, search, rename or delete files on the SD card.
*SMS
Read, send, forward or delete SMS messages.
*Applications
Install, uninstall, backup, search apps and do batch processing.
*Photos
Preview, delete, import, export, set as wallpaper and photos slide show from desktop.
*Clipboard
Share clipboard text between desktop and device.
*Contacts
Group, search, create contacts, check and delete call logs.
*Ringtones
Search, preview, import, export, delete and customize ringtones for phone calls, notifications and alarms.
*Music
Play, search, import, export, delete, or set as phone call, notification and alarm ringtones.
AirDroid also comes with the following inbuilt features:
*Device Status
Real-time ROM, SD Card, Battery, CPU and RAM status report & monitor with charts to demonstrate available/used/total resources, and one-tap memory boost.
*Tasks Manager
Kill or uninstall running apps, batch operation supported.
*Apps Manager
Uninstall, share or check details of user and system apps.
*Files
Control Cut, copy, rename, send/share, delete, sort and create visible or hidden folders and files.
*Files
*SMS
*Applications
*Photos
*Clipboard
*Contacts
*Ringtones
*Music
*Device Status
*Tasks Manager
*Apps Manager
*Files
