Missing_Link
Member
Hi all,
One big problem I've noticed is that when you need to have your phone switched off (e.g. on an aircraft, etc.) it's all too easy for the phone to switch itself on whilst in your pocket - the "power on" button just needs the slightest tap and then it springs into life.
I know whilst on a plane I could pre-set it to in-flight mode before powering it off, but that's not the point. Like when powering the phone off, there is a delay and a set of menu options. I'd like something similar for powering the phone on - programmable delay and/or combination of pressing say home and the "power on" button.
Does anyone know of an app or some code I could run to alter the way the phone behaves ?. Not sure if the only way to add this functionality is part of a flash update as it needs to survive a power off, etc.
Any ideas please guys ?
Cheers.
Cheers.
