CoolReader on Nex 7 (2013)
dmRaz
Has anyone successfully installed CoolReader on the new Nex7? It keeps crashing on opening in two different builds I've tried. I save a lot of clips in rtf and its the best/only reader I've found so far that can handle that format.
thx,
thx,
Hi:
It works fine on stock. I had to use a larger font to make it readable on the higher resolution screen.
Tom
