CoPilotLive satnav on Pulse
Hi again,
Is anyone here running the free CoPilot ( UK ) on their T-Mobile Pulse ?
On my phone this app sometimes comes up with " no maps installed " . I have to uninstall and reinstall quite often - whether the phone is left on or turned off and on again.
Regards
Hi again,
Regards
I'm having exactly the same problem.
It seems to work following the initial installation, the next time you need it, the 'no maps installed' message pops up and you are going nowhere.
All the files are there, they are just not getting accessed - I notice a '?' in the folder icons.
I've got some instruction off the Copilot people to reinstall it with a soft reboot - whatever that is!
I'll give it one more go, but something is amiss. Everything else seems fine on the phone BTW.
Annoying. Google Maps are offering some Navigation possibilities...
