Root Copying themed widgets between ROMs?
esmith818
If I know I like a particular themed widget, but flash a new ROM and like everything about it except that widget, is there a way for me pull the widget from the old themed ROM and replace it on the new?
(The calendar widget rarely gets themed for some reason. I am using Pure Calendar now, but it's not an exact match which is mildly annoying.)
Here...try this GSFYv1.6_Stock_Gmail_&_Market.zip
This is how I made that file:
- You just take the Galaxy S theme and open it with WinRAR or 7-zip (open it...do NOT unzip it).
- Navigate to system > app
- Delete everything in that directory
- Open LFY 1.6 the same way.
- Select the apk's that you want to move over to the theme (in this case I moved gmail.apk and vending.apk)
- Copy those over to the Galaxy S theme (just drag and drop in the same screen you were in when you deleted all the apk's).
- Close the application windows (WinRAR or 7-zip)
- Put the "new" theme on your sdcard and flash like you normally would
Enjoy ;)
http://androidforums.com/liquid0624...22d-built-source-get-fast-before-melts-5.html
replace the above ROMs and themes with your's.
Same process...
