Help Corp Calendar
rweddy
My company uses Google to host our email, web-sites, etc.
We don't use exchange at all, and I am trying to figure out how to get my Calender to show up/sync/etc. on my phone?
Thanks
Pretty sure no direct way to sync without exchange.
You can try google outlook sync or any number of other third party apps that will sync your outlook calendar to the google calendar, which will of course sync to your phone.
Thanks for the reply, what I figured out is that currently 2.0.1 only supports one calendar which is the 1st gmail account you set up on your phone.
Since my company uses google to host our emial, website, etc. it wont let me add this calendar in, and we don't use exchange I think I am S.O.L.
Any ideas? Now as a work around I can access from a web browser, maybe this will be fixed in 2.1? Any dates on when the Moto Droid will get 2.1??
I think you can share your second calendar with your main gmail account and then enable that shared calendar in the calendar app on the phone. you will st least ne able to see the calendar on the phone app, not sure if yoi can edit or add rvents though
