There's no such thing as Office 2002. Also, the version of Office that you're using is pretty much irrelevant as far as remote sync is concerned - Exchange version is what matters (needs to be Exchange 2003 SP2, or Exchange 2007).
Also, your IT department needs to have it all setup correctly. Exchange 2003 is MUCH harder to do this with than 2007.
If a Windows Mobile phone works, a Droid should as well.
I got the Droid today, the "Corporate Calendar" has all my meetings on it. Works Great. The only negative is that all the widgets out there and other calendar apps can't use it because it isn't part of my google account. I really wanted an agenda view in a widget.
Oh, and I am the IT guy for my company. Yes, if a windows mobile phone syncs, then this should too. It was VERY easy to setup. We are using Exchange 2007. Outlook version doesn't matter.
My corp calendar is working. Exchange 2007.
I am also the IT guy for our company as well and I was having that same problem of "authentication failed".
I removed my corporate account on the phone, set it up again, and the calendar started working.
That is all I did for it to work.
We have exchange 2003/sp2.
I just wanted to say thanks to hagar852 for the simple solution and if you are having this trouble and try this fix, let your Droid sleep on it overnight and you could get the same results as me!I wish I could just find a way to use Exchange even though I don't work for a company that uses it. I just wanna use it so I don't have to use my POP3 e-mail settings and have to worry about pulling from my verizon.net e-mail address every 5 minutes to get my e-mail and wasting my battery.![]()
is it possible to sync 2 corporate calendars with my droid ?
this may be unique, but i use a departmental calendar and a personal calendar at my job. both are outlook exchange calendars and both are pretty important. im a supervisor so i need the departmental calendar to keep track of employees and my personal corporate calendar for meetings, tasks and agendas etc......
thanks folks !
