Hi all Hopefully someone has an answer...
I set up my corp exchange email account and the email part of it works flawlessly. The calendar on the other hand is very quirky.
On the first Sync I noticed that not ALL appointments were brought over from my Outlook Calendar. Upon researching it seems that the meetings not coming over are all recurring meetings. Some were from other people that I was invited too but most were recurring meetings I had created on my own calendar.
I did some testing to isolate the behavior:
Create single appointment in Outlook
It shows up perfectly on the Fascinate.
In outlook change the appointment to recur monthly
Appointment VANISHES from Fascinate.
Remove recurrence from appointment in Outlook
It comes back to Fascinate.
The same behavior can be seen when creating a fresh appointment with recurrence.
The problem seems to be isolated also to recurrence set for the "every third wednesday" or something similar. It works for monthly on the 20th for instance.
ANYONE else having this issue?
Firmware version is: 2.1-Update1
Build: SCH-I500.DI01 (downloaded today and did not correct sync issue)
