Help Corporate sync problem
Anaclya
I am having an issue syncing my corporate exchange account with my Droid Bionic. It says that the server isn't correctly formatted. I'm thinking it is because it is a UK server so it won't accept the TLD co.uk. I've seen other with this issue for other TLD's but only threads from 2010. Does anyone know a way around this?
Exchange also won't configure on a phone that isn't activated if that helps ya.
Otherwise don't use the url. Find the ip for it instead and hope it is static.
Try going at it with the servers IP#. Are you using HTTPS? I would start without it first, if you can.
