rijul zalpuri
hey guys i created this topic so poeple with  problem like my can benefit from this rom
i was facing a lot of lag after flashing this rom but a few steps were neccesary which boosted the rom
Just open the ROM zip.
Go to system>etc>init.d
And delete all scripts except these
1.link2sd(if present)
2.apps2sd
3.banner
4.zipalign
5.Megascript
thanks varun for these steps
delete all other scripts which are present use a desktop or a laptop to edit the file
after u hav done this much
replace ur megascript file with this one
http://androidforums.com/attachment...new-link-rom-hybrid-iii-aka-v3-megascript.zip
thanks varun again for this
now In recovery, n recovery mod clear out ur
1. factory reset
2. wipe cache
3. advanced->wipe dalvik cache thanks mastermind for these steps
4.flash the ROM
it is giving me a quadrant score of 800+ on avg and by using task killer and then runing teset it reaches 850
this should do the trick the mobile is moving like a train
2.apps2sd
3.banner
4.zipalign
5.Megascript
1. factory reset
2. wipe cache
4.flash the ROM
