Root Corrupted internal SD-card
iliasky
I installed Nero v3 TW Rom (min first Rom) and i loved it ,i installed the voodoo 5.0.4 update to.Everything was fine until I tried to make a SD-cart partition :roll: for apps with- Rom Manager - the pone couldn't boot ,it got stock on the vibrant logo .I tried to flash it to stock 2.1 with Odin -it did't boot .Then I tried to flash 2.2 with Odin -it did boot and everything was fin except the internal SD- card --was broken ,I can't install any apps on it !!I know that its a software issue and I need help to fix it... :oops: ! I can put fills and music on it through the PC . Shod I try to format the internal SD from the PC>?? Pl help.
Okay, can you manually boot in to recovery at all? If so, even if it's not CWM no worries. Try clicking reinstall packages a few times and see if that takes you in to CWM recovery. If not, under reinstall packages there are options to wipe data, and wipe cache. Do both. Then try to get in to CWM again through reinstall packages. If you get in, re-flash Nero, and start again. If not, try the Odin method again. If none of this works, there is a hard brick method for Odin that you may want to try. I'm sure someone else here may have some things to add to what I said.
I don't haw CWM recovery installed on the flashed 2.2 - I got know ,and i cant install Rom Manager app...! Wen installing 2.1 ore 2.2 with Odin I got "data clean error" --only 2.2 boots.Can I install CWM ore Nero true Odin ,ore true a zip fill?And haw dos the hard brick method for Odin works ?:(
I had the same exact issue as you bud. You can see my plea here. What I did after days and hours on the phone with someone trying to help was watch the nobrick video from akaskriller on youtube and I was able to fix it with no problems at all in the process. If you need all the files I have them on my dropbox.
http://www.youtube.com/watch?v=dMtlR3euX24
EDIT: Here is the link to my dropbox with all the files needed. Included is the stock 2.1 rom and eugenes froyo that I am currently running. The total size uncompressed is 750mb but should be smaller since dropbox compresses the folder before you download it. You can flash either one when it comes to that point of flashing one, just be sure to watch the video for proper instructions.
Akaskriller is great. You can even donate 5 bucks and get access to tons of custom roms and other stuff. That guy who was helping me on the phone for 3 hours on xmas eve night was awesome enough to give me his login to check the place out and I have to say there is so much more on there. I personally will be donating to their project once I get more money though. I installed a different froyo rom from akaskrillers site about an hour ago and I am loving it thus far. Below are a couple of screenshots I just did. Using a similar rom to the one you tried, I watched a video on how to do it and it worked great without issues and as expected it took a little bit to complete the setup.
EDIT 2: changed my boot animation and now it says this.
Just joined and about to donate , big thanks to CptGemini , i have tried so many tutorials and videos to restore my bricked Vibrant... Yours worked flawlessly the first time!! thank you!!!
I've become so active over there that they made me a forum admin and gave me a lifetime membership to the site, I have more posts than anyone there lol.
wow , thaz crazy , thats hot though!! i wouldnt disagree with their decision at all!!! good job in all that you do!!!
the screenshots above , i want that exact same layout on my phone.. i knw how to root the phone using ryans lag fix , whats the next step?? i still have the froyo zip file that was included in your drop files box..is that essential?
its just a livewallpaper that came with the rom i was using at the time since i was still learning my way with flashing stuff but now i know a lot more. below I attached a screenshot of my current setup which i like the most. btw they will have a picture of me in the donation area of akaskriller.com alongside the rest of the helpful people listed there.
