Root Could someone help me flash Perception?
HeXiiK
Member
If some one could, i would like if someone could give me a step by step direction on how to install this. I've tried countless times and it doesn't seem to work. Instead of figuring out what im doing wrong can someone just give me a step by step of what you did? Then we'll see if it goes wrong. If you answer this, give a link to the perception build you used so i can download it. Preferably the newest version! Thanks so much!!
http://forum.xda-developers.com/showthread.php?t=848115&highlight=voltage+control
since you said youve tried multiple time im assuming you have clockwork recovery and rom manager, with all your apps backed up with titanium backup. if not i will edit and put them in next
download the .zip either to your computer and transfer to your phone, or straight to your phone
open rom manager and select reboot into recovery
select apply .zip from sd card
find the cognition .zip file and select it
the rest does itself
[ROM]Perception Build 7 (CogKernel2, uv/oc, Voodoo5, tons of tweaks) - xda-developers
Does rom manager method work if u have custom rom? like i have cog and i want perception..so can i use rom manager without flashing it back to stock rom?
it will theoretically work, but i flashed back to stock inbetween going from cognition and perception. i know the dev recommends going stock and but i know for sure you have to disable voodoo first. i think its probably faster to flash stock and then flash perception then disabling voodoo and then theres the chance of a soft brick
but u have to be on computer to use Odin...i was just wondering any way to flash back to stock without using computer,,,
not that i know of. i wouldnt try flashing without access to odin though because ive had problems going from stock to a new rom so i wouldnt take the chance of bricking without a computer especially going between 2 custom roms
I tried...and it was going on recovery whenever i stried to start it,.....had to reflash stock using odin...lesson learned it doesnt work..
but I have used rom manager to install zip files for themes and new updates to rom....works superb...
