kellysa111
So, as some of you may know, since the 2.1 update and the update for the HTC Sync, my phone has not been connecting to my laptop. It does connect to charge, but I do not get the notification icon asking how I want it to connect (i.e. as a disk drive,htc sync etc..). After downloading the HTC sync software for my windows 7 laptop, I went into my device manager and searched for the adb driver. To my surprise, it wasn't there. The last time I installed HTC Sync, the driver was there, and it worked for like 2 times. Then, I updated my phone and had to update the HTC Sync, and from there started the problem where the phone is charged. To make things easier for you guys, I did go under settings and clicked on the type of connection I want the phone to go through when plugged into the laptop.
So, my question is... Could the missing adb driver be the problem as to why the phone is not connecting at all? And if it is that, where can I find just the driver since I have the HTC sync software.
