.... right outside of Dallas (Coppell, 75019). The lady said it wasn't available for my area yet. I guess Dallas is not fully 4g ready?
My location is clearly (pun intended) in the green coverage area on their website maps too.
im not trying to use a data card...im trying to use 4g for my home pc and home laptops all at once to replace my verizon internet
Clear.com High Speed Mobile / Wireless Internet Service Provider
dude... a 4G signal is a 4G signal... i'm NOT telling you to buy a 4G card TO REPLACE a 4G modem but simply - as stated above - take one home to TEST THE SIGNAL (and then return it the next day after you've determined if you truly have a 4G SIGNAL in your area or not)...
just keep believing whatever crap "the lady" is telling you and will til she gives you the OK...![]()
Why don't you try keeping it positive. A 4G signal is not a 4g signal...sorry its not.
A USB device does not have as big of an antenna so it won't pick up as well.
Also not all home modems are made equal. I am a bandwidth junkie and only get about 3mbs up with each clear modem I have however two of them drop more then the 3rd
Someone posted that their 4G USB stick is getting better results/DL speeds than their EVO, in the same location.
