Help "Couldn't install on USB storage or SD card" issues with installing apps
mchype14
Hey all,
So, I'm running Velocity 1.2 and it works great. However, There seems to be an issue with installing some apps. I have the default App install location set to auto, but there are some apps that won't install with an error of:
when it tries to install.
Does anyone else have this issue? Or is there a way to fix it?
It only started happening when I tried flashing a new theme (Thunderbolt) which screwed everything up, so I wiped everything, reflashed Velocity1.2 and it was working fine. Then I started getting these errors. Is it because it was still having issues with the .android_secure folder or something?
Any help would be much appreciated. Thanks!
So I found a temporary fix for this... and it is pretty much contradictory to what we want...
It seems that the apps that are getting these errors are not meant to be put on an SD card. So... if you go and move them back to the phone's internal storage and then try to update them, it should work.
It's what worked for me, but there is a reason we have a2sd and we were able to move them to SD in the first place...
Oh well..
i almost gave up on this problem. but there is hope! haha. if you cannot see the file using file managers like astro in your phone, try mounting it in the pc.. works fine with me.. ^^
Ya! right "papporght" this also worked for me... I've connected the phone to the PC & searched there, there i got it & its about 8.21MB of size... Thanx!!! Dude...
