Help Couple of issues
JDY
The first issue I'm having is with Facebook, for a while now when ever I go on someone's profile the bar at the bottom which says 'Wall' 'Info' Photos' is never present. If however i open the contacts app on my phone and go directly from there to their facebook profile i see the bottom bar.
Image straight from contacts to profile:
Image from Facebook to profile:
So any ideas how to fix this? I've uninstalled facebook but will also try it again.
The second issue is that I can never seem to update multiply apps at a time. For example if I have 3 app updates I click the update all button and then instead of them all updating at once they update one at a time which can take a while. Any ideas?
The FB thing is beyond me.
Updates are done one at a time, since they use a portion of the phones partition memory as cache for installation and unpacking. That is why you need the 15 Mb of space in order to install or update your apps, or suffer the dreaded low memory warning.
