Root Couple problems with GB Deodex & Overclock
SimsDelt
Android Expert
So I used P3's deodex (new one) and still get FC's... currently flashing airmax's. Hope it works. But I'm also having a problem with Jrummy's overclock. I can get it to work fine, but it won't stick on boot... anyone else have that problem or a fix for it?
It seems like none of the overclocking apps are sticking after a reboot and you should be fine after after installing the other deodexed file.
Got jrummys overclock to work on boot. Once its open go to settings and then boot type and change it to root instead of android system. It will pause 60 seconds on boot but then will apply the settings.
