Root couple questions regarding backup
mikem0269
Android Expert
I just rooted my evo and first did a backup with cloclwork mod but read that amon ra 2.3 was better so i did a back up with it also. So now can i delete the clockwork mod back up and also can i delete the zip file for both or just clock work mod? Thanks in advance and the instructions were great. no problem rooting on my first try.
I'd keep the amon ra file somewhere just in case you ever need it again. Sometimes things happen and having a recovery on hand could come in handy. Just my 2 cents.
I kept the back up file on the sd card and copied it to my hard drive also. I just had 2 back up files and the clockwork file was over 600meg.
Thanks for the info.
Yeah, you'll want to keep your stock Nandroid for future use (wimax mainly), but I just threw my amonra file into a folder ... so it looks like this ...\AmonRaRecovery\PC36IMG.zip
That way, the file is ready to go, no worries about renaming it.
