cashmere_cat
I have a few questions that I can't seem to find answers to...
1 - How can I see what partition I have on my SD card? (not size, but ext3 or ext4)
2 - How can I find out what class of SD card I have?
3 - Thinking that I should change from ext3 to ext4. If I understand correctly, ext4 is a better choice. It seems that a number of ROMs list ext4 as preferred. And if they list ext3, 4 will work also.
I was looking at [ROM] SUPERNOVA Xtreme Official GB SENSE 02/Dec| 2GB INTERNAL MEMORY|Optimized KERNEL - xda-developers which says: Partition Required: FAT32 Primary followed by One ext4 partition (ext2/3 if present will be auto converted to ext4)
I like the sounds of that - install a ROM and it will change the ext for me
Any downside to doing it this way? If I wipe SuperNova off, will it automatically revert back to ext3?
