Help Couple questions
nikeman
I have downloaded and upgraded to the pro version of the jellybean keyboard and I am liking it a lot. I like to close out everything that's running in the background a few times a day but it seems like when I close all from the task manager and use the keyboard again it is back to the default Samsung keyboard. Anyway to prevent this?
Also, why is Google play music always running in my task manager even though I have never used it?
This is just a frustrating issue of Android. When I got my first Android phone I saw all sorts of apps that just were open on their own. I was told that essentially Android likes to preopen an app to anticipate your needs. I am not sure how it knows to do this, unless messing with ringtones or any other sound makes it assume you will want to listen to music soon.
You need to select the Jellybean Keyboard as your default keyboard. (You have to go into the setting menu for keyboard.)
