Does the Incredible by default use CPU scaling? I using system panel and the clock speed seemed to be going between 700 to 800 mhz.
If that's the true, what is the purpose using SetCPU?
Also under CPU info it says Min CPU is 245 and max is 998. Is that just stating what the hardware is capable of or what the software is using for scaling?
