Root Cpuboost (free) question
What is invisible mode? The menu doesn't give a full description and I can't find info a anywhere.
I have an idea what it is,but,just to be on the safe side for accuracy of information, try dropping the developer a line at his e-mail address,it's listed in the market with his app.
I have firsthand knowledge that he is very responsive to feedback from all who correspond with him.Please share your findings with us here in the forum!:)
Invisible mode basically turns off all background services(which will disable widget updates and profiles you have set up) . I added it for people who just want to change the speeds of the phone and then close the app without the app using any resources at all in the background. The set at boot option will still work in invisible mode.
A voltage, and current indicator, would be welcome. Is there a setting that can read the capabilities of the particular phone, and adjust the temperature to a safe level? Off question, does anybody know of any cases that come with some sort of cooling options?
I would consider 614400, a mild overclock, 39c a safe temp for the huawei ascend, does anybody agree?
