Root Crap did I screw up?
jasondhsd
Member
Ok I just installed the 2 zip files from the sticky via Clockworkmod recovery. I was expecting to reboot expecting to find all my data and apps gone, which is why i ran titanium backup before hand. But I was surprised to see all my data and apps still loaded. Did I screw up? Was I suppose to wipe before installing the 2 zip files? Everything seems to be functioning property, the UI looks blue and I have 4 touch buttons (phone, address, text msg, app drawer), plus About phone says I'm now running android 2.3.3. Did I do it right or did I screw something up that I might not be noticing?
Well, seeing as how everything is working right and it shows that you are on 2.3.3, I would say you did things right. I'm not sure why you think you would have screwed up. Lol
Because I thought installing the pre-rooted gingerbread files would automatically wipe all data and leave me with just the "default" settings.
No, they won't. If you wipe, then your data and settings would have been lost. It's like any ROM for testing - you don't get /Data and /Cache overwritten unless you manually wipe them first, in most cases.
