try to download apps that can create playlist. mostly its m3u file. after creating the playlist, it will not appear yet on the default music player. try restarting your phone then afterward open the default music player you will see it is updating. then check the playlist...
hope it works for you. the only problem now is deleting playlist from the default music player...
