oamilcar
I decided to make this thread to make it easy to find for others that may have problems w/ sounds as well.
Why not make your own custom one? To make your own .ogg sounds which is a raw format I like to use audacity. Is a super nice sound editor where you can grab any mp3, and edit it to your liking, then export it to an .ogg format.
Sry my computer die so can't give you exact instructions on how I do it. I have helped dev adding customs sounds to their roms, from lowbattery charge sound, charging sound, ect.
I found this instructions which may help you creating one your self w/audacity. http://wiki.commedia.org.uk/wiki/index.php/How_to_convert_from_any_format_to_WAV,_MP3_or_Ogg
If those instructions don't help Google is your best friend.
Edit: or maybe this instructions.
http://forum.xda-developers.com/showthread.php?p=39520163
no low BAttery Warning ogg file..anywhere..it seems it was deleted or just not read properly...so i made my own...
its the ironman, "we are now running on emergency backup power" when it gets to 15%
i made it flashable...or you can unzip it and take it..either way...
i was confused for an hour as to why my battery never warned me...lol
i made this flashed zip so just run it in recovery and its digitally signed...
if you have issues with it,
if you have issues with zip:
1. extract files, lowbattery.ogg
2.move it to your phones, system/media/audio/ui (youll need root access)
3. for permissions: rw-r--r--
.zip file here http://androidforums.com/showthread.php?p=5970724
I have this and love it! The flash able zip does not work justs aborts. Manually adding is alrightthank you for this. Also were can u get more if you may pm ?
yea the flash wasnt working...the older way used to work...maybe i can fix it later...
The jarvis sounds are just by google, there are not many that are raw sound bits, the others, have the movie music in the background
if there was a HD quality sound board or something i could take the sound bits and theme them
