pcwebiz
I received a Cricket Samsung Vitality and flashed it over to PagePlus Using QPST with no problem.
I made a backup of the ROM and Switched over to Open Android thinking there was a APN option in the menu. There wasn't.
I restored my backup using Clockwork recovery 5.0.2.7
I rooted the backup wich is the original Cricket Vitality ROM with Admire-2.3.6-Root.
Now ##DATA# no longer works. Settings/About Phone/Status instantly turns off the phone.
I restored my backup again so I would have it installed without Root. Did not fix the problem
If anyone has a suggestion or solution to this problem I would really appreciate your response.
Thank You
Thank You
