i updated my phone 2.3 and somehow didnt have the cricket stock apps so i need the cricket myback up so i can get my contacts back again is there a way i get some of the stock cricket apps?
I would contact Cricket. Usually the apps that are particular to a carrier can only be recovered with a hard reset. If there was an issue with the update, they may be aware of it.
Well, if worse comes to worst, you could backup your apps and data, flash to stock, get your contacts, back them up with your Google account (which is not only the easiest way, but the only way I really trust) and reinstall CM7, your apps, and your data. There are worse ways to kill an hour.
