Do any roms have the crt on animation enabled? I've been trying to get this working on the stock Rom and following two different guides I've had no luck. Any help would be great
#debug.sf.hw=1
<bool name="config_animateScreenLights">false</bool>
adb shell
su
stop
mount -o remount rw /system
cat /sdcard/framework-res.apk > /system/framework/framework-res.apk
chmod 0644 /system/framework/framework-res.apk
mount -o remount ro /system
reboot
i already did the bools edit, all that does is enable the crt off effect....
as for CM 7.2, does that have the crt on animation? or only the crt off?
Try cm7.2 the crt animation is smooth and fluent
In all fairness, I made the same mistake..It doesn't have the on animation.
look at the post before you make a comment kthx
Cool, thanks. I'm still playing with it also, and IF I get it I'll be sure to share
)..How do I change my SD card to READ/WRITE? When I edit my build.prop it wont save...
I'm stuck!
